Hello everyone,
I would like to see your definitions, your opinios and generally a discussion about steam.
Let me add some definitions:
Saturated steam is steam that is in equilibrium with heated water at the same pressure, i.e., it has not been heated more than the boiling point for that pressure.
Saturated steam occurs at temperatures and pressures where both steam and water can coexist, which is when the rate of water vaporization is equal to the rate of condensation.
What is the difference of saturated steam and saturated water?
The steam enters a turbine is a superheated steam and in the outlet of the turbine is a saturated steam??
