Hello All,
I happened to work on Heat transfer calculation recently and have a doubt on the heat transfer through radiation.
Considering an insulated wall/pipe having heat source from inside (gas), we know that the heat transfer happens from inside through convection+radiation then conduction through wall and finally convection+radiation outside to the environment. But when I went through the example calculations and spreadsheets I noticed that the radiative heat transfer co-efficient from inside is often neglected and only the convective heat transfer co-efficient considered. However for the outside I can see both convection and radiation heat transfer co-effts considered in all cases.
Could some on throw some light on this. Thank you so much.
Neel
Mechanical Engineer
