Hydrocyclone Modelling And Simulation In Hysys
Posted 15 December 2018 - 01:57 PM
I wish to model Hydrocyclone in HySys for oil and gas facility. How should i approach this?
Best Regards,
Chetan Chavan
Posted 18 December 2018 - 09:01 AM
HYSYS is a thermodynamic simulator. You can model this as a separator. The simulator has no knowledge of the fluid mechanics of the internals of the hydrocyclone (for oil/water separation). If you need details, contact a hydrocyclone manufacturer.
Posted 19 December 2018 - 06:40 AM
Dear Sir,
I am using two phase separator for this.
I can use carryover option in hysys for modelling separation of oil and water , but how to control vesel pressure as there is no vapour line shown on P & ID. Also there is no vessel pressure controller.
Request your help.
Posted 21 December 2018 - 09:24 AM
A hydrocyclone controls the backpressure of the liquid outlets. In HYSYS you set the pressure of the inlet to the vessel and connect a vapour outlet that will have zero flow.
Dynamic Simulation - SeparatorsStarted by Guest_tomr91_* , 10 Mar 2025 |
