Oilfield Indirect Heater
overall heat transfer coff. indirect heater coil area coil sizing
#1 elhady3000
elhady3000
  • 6 posts
Posted 20 December 2018 - 02:27 AM
hi everybody,
i was asked to design oilfield indirect heater with duty 8.5 MMBTU/hr in order to bid in favor of oil company, the problem is the coil i had calculated is very big, here under the specs of heater and i will attach the calculation sheet i made to calculate the coil area.
water bath temp. = 85 C
oil inlet temp. = 25 C
oil outlet temp. = 60 C
assumed coil diameter = 4"
Duty = 8.5 MMBTU/hr
please check the calculations and see what is wrong
Posted 20 December 2018 - 11:38 AM
You have not attached your calculations.   Try again.
Have you read and studied the design literature I prepared and submitted on this topic?  Go to:
https://www.cheresou...direct-heaters/
#3 Dazzler
Dazzler
  • 140 posts
Posted 23 December 2018 - 06:50 PM
There are OEM's that specialise in the design and manufacture of these WBH's.  I work at one of them.  So another option for you is to state which country your end user is located in the world so that someone can advise a reasonably closeby OEM that you could contact.
Your duty of 8.5 Million BTU/h converts to 2.5MW which is a medium to large size.
Edited by Dazzler, 09 March 2019 - 12:16 AM.
