Hi all
There is a biogas stream containing 53% Methane, 44% CO2 and 3% H2S on v/v dry basis. The amount is 7500 NM3/hr at ambient temperature and about 0.5 bar,g.
Does someone has a economical way of removing H2S to the level of 100 ppm or so.
Thanks in advance.
Samir
H2s Removal
Started by Samir Gupta, Sep 18 2006 07:18 AM
Posted 18 September 2006 - 07:18 AM
Posted 18 September 2006 - 08:16 AM
The obvious method is to have a compression step followed by a Gas Sweeting Unit based on absorption of H2S as well as CO2 by an amine solution. See for example:http://www.simtronics.com/catalog/spm/spm3100.htm
Posted 18 September 2006 - 10:59 PM
If only hydrogen sulfide is to be removed, a solution of potassium bicarbonate can be effective. Since hydrogen sulfide is low, solid absorbents like hydrated ferric oxide can also be tried. You may try Puraspec absorbents/adsorbents. (www.jmcatalysts.com)
P.K.Rao
P.K.Rao
Posted 19 September 2006 - 02:58 AM
QUOTE (gvdlans @ Sep 18 2006, 06:46 PM) <{POST_SNAPBACK}>
Thanks dear for your suggestion. However, I want to selectively remove only H2S and then recover CO2 by Amine process. As H2S and CO2 are equally adsorbed by MEA, I want to get rid of H2S before taking the gas stream to MEA process.
Samir
![]() Moisture Removal From Blower AirStarted by Guest_Makarove_* , 12 Jul 2024 |
Co2 Removal Membranes Between Compressor StagesStarted by Guest_Sinclc_* , 26 Mar 2024 |
Carbon Filter Used In Hot Benfield Solution For Co2 Removal In AmmoniaStarted by Guest_Abhishek Taware_* , 14 Jul 2023 |
H2S Removal From BiogasStarted by Guest_Aliceat2000_* , 24 Jul 2022 |
