This is the first time that I write here , hope that it wont be the last , any way
I have attached to you simple sketch of existing degassing stage where the crude oil with associated gas fed to the First degasser (as you see in the sketch).
my question is regarding the GOR mention in the sketch , do I consider that that the GOR mentioned at each stage it for the inlet to separator ?
more clearly , for the second separator (OP conditions : 85.3 PSIA & Temperature 100.4/127.4°F) , does the quantity of the gas outlet (P2) will be GOR X BBI or no ,
Does the GOR for each separator given is the quantity that associate the liquid bottom for each separator?
my understanding that the gas quantity represented in each stage , will be remove (even if not totally) from the top of the each separator.
so that for the new unit that need to be installed (Wet Crude Oil Treatment Unit) (outlet from the second existing degasser) has no gas quantity or even neglected quantity.
as you see , the quantities and operating conditions of the unit was represented as a table (as you see in doc 2,available technical specification).
hope that I can find an answer from you ![]()
