Density Difference Upstream And Downstream For Orifice Flow Meter
orifice flowmeter compensation
#1 james.corrobro@gmail.com
  • 48 posts
Posted 26 January 2019 - 10:39 PM
hi,
i got to look at some P&ID for orifice type flow meter (attached similar). I see that they use pressure  measurement upstream of flow meter and a temperature measurement downstream of flow meter for density correction for gases.
Since there will be some pr. drop across orifice and some temp, drop across orifice (due to J-T process). Should we not measure pressure and temp. upstream and downstream. Please help on this,
  • 6,897 posts
Posted 26 January 2019 - 11:17 PM
They should be able to get access to the pressure (calculated) [ Pabsolute - Delta P orifice]  combined with the temperature to deliver a density (calculated) .
Take a look at the set up from Spirax Sarco , quite similar .
Definitely Pressure and temperature must have the same reference (upstream or downstream the orifice).
hope this clears your doubt.
Edited by breizh, 27 January 2019 - 12:01 AM.
