Hello All
We have chosen Topic of Dehydration of natural gas by using Liquid desiccant TEG and Solid desiccant Mol. Sieve.
1st part
Dehydration before a shallow cut unit which is a TEG Process and in simulation we need to meet 4lb water content/mmscfd of delivered gas
2nd part
Dehydration before deep cut u nit which is a mol. sieve and in simulation we need to remove all water content from the delivered gas and the rate of bed regeneration heat should be removed.
We have done 1st part and trying 2nd part but there is no option of adsorption unit in hysys. As professor suggested to add LPG recovery unit as a sub section part of your 1st part TEG simulation. This is confusing , how we can run both simulation in single sheet as there is no option to add adsorption column in hysys except we can go for Aspen Adsorption simulation model (Adsim)
For solid desiccant part I tried to prepare simulation with different composition by adding component splitter with the help of google findings but not able to complete that part. Could you please help us in this regard How should I go with this. Could anyone share this kind of hysys model. I am not able to share my hysys file here.
I will be very thankful to you.
Thanks & Regards
Satyam Arya
satyam.arya1@ucalgary.ca
