I have to size the PSV on discharge of centrifugal-compressor for blocked outlet case.
I have vendor curves (discharge pressure vs Flow, shaft power va flow) available with me.
can anyone tell me how to calculate the relief rate for the PSV? I read the other articles on this. i got following steps:
Relief rate should be calculated at maximum suction pressure, but also RELIEVING pressure of PSV on compressor discharge. To exactly calculate relief rate for such a case, follow steps below:
- Get compressor head versus capacity curve for maximum speed
- Calculate maximum compressor suction pressure
- Calculate maximum compressor discharge pressure going backward from PSV (at relieving pressure) to compressor discharge flange
- Calculate compressor differential head from suction and discharge pressures
- from compressor head - capacity curve, read capacity corresponding to above calculated which is relief rate for your PSV.
However, i could not understand, how to proceed with the calculation?
if anyone has any reference calculation available with them then kindly share.
thanks in advance
