Hi friends, I am doing my project on Liquefaction of Gas using HYSYS. I am doing Mixed fluid Cascade process (statoil-linde) and Dual Mixed Refrigerant Process. I have given the feed composition, temperature, pressure and the flow rate. Can you please tell me what will be the pressure drop in the exchanger. If you have any idea about Statoil linde please let me know.
regards
Shanti
Statoil-linde
Started by shanti1927, Sep 20 2006 12:40 PM
Posted 20 September 2006 - 12:40 PM
Posted 13 December 2006 - 10:18 PM
I will take a look to my books to help you , me I know the following process cycle:
1- cascade cycle using almost about 24 small compressors using three different fluids.
2 - Pritchard cycle
3- Lind cycle
4- Teal cycle
5- MR- C3 precooled cycle
and each cycle has a specific efficiency , you can see the difference betewwen the all by calculating delta H ( cooling curve and heating curve to know how much enrgy is used to liquefy natural gas and what is the delta T beteween the refrigerant and the NG (ideally 0.5C).
2 - Pritchard cycle
3- Lind cycle
4- Teal cycle
How Do Linde Modular Plants Work?Started by Guest_goggles3000_* , 21 Oct 2017 |
Hysys: Linde Cycle -> Heat ExchangerStarted by Guest_dummyad_* , 25 Sep 2014 |
Linde Cycle V/s Claude CycleStarted by Guest_Light_* , 13 Dec 2013 |
Cryogenic Air Separaion Unit: High Pressure Linde ColumnStarted by Guest_rashood_* , 25 Sep 2012 |
Hobby Scale Linde CycleStarted by Guest_babakfarhadi_* , 05 Aug 2012 |
