Please can anyone help on this topic?
Posted 05 April 2019 - 06:46 AM
Posted 05 April 2019 - 07:43 AM
Would the heat required be the heat that is being lost? I would think that would be the most likely preliminary size of the heater required.
Posted 05 April 2019 - 08:15 AM
what are the parameters needed for the sizing? what is/are the sizing procedures of electric gas heaters
Posted 05 April 2019 - 08:55 AM
I would think the parameter you should aim to acquire first would be the heat losses in kW.
Conceptual Sizing Of Adsorber ColumnStarted by Guest_JJvdM_* , 24 Oct 2019 |
Separator SizingStarted by Guest_HOTTEST_* , 12 Mar 2026 |
