Pump Minimum Flow Line Control Valve Fail Position
pump min flow control valve fail position
8 replies to this topic
#1 rs20170808@gmail.com
  • 41 posts
Posted 18 April 2019 - 06:12 PM
What should be the fail position of pump min flow line control valve? The pump min flow is routed to the suction tank? what should be the rationale for selecting fail position
#2 Bobby Strain
Posted 18 April 2019 - 10:39 PM
I have always applied a philosophy that a control valve should fail closed unless there is reason to do otherwise.
#3 Chemitofreak
Chemitofreak
  • 292 posts
Posted 19 April 2019 - 03:46 AM
I have a difference in opinion with the above answer.
Minimum flow line is provided on a centrifugal pump to save the pump from the following consequences:
1) Impeller damage
2) Overheating of casing and bearing
3) broken shafts etc, etc
The pump should always run above the minimum flow, hence the control valve on the minimum flow line shall have fail safe position as 'Open'.
Revert in case of any query.
#4 fallah
  • 5,019 posts
Posted 19 April 2019 - 04:56 AM
The fail position of a minimum flow control valve should certainly be "Open"; because in the cases in which the discharge flow is going to be below minimum flow, the minimum control valve might has already been failed hence cannot compensate the flow shortage if it had been set to be failed closed...
#5 rs20170808@gmail.com
  • 41 posts
Posted 19 April 2019 - 05:30 AM
hi fallah,
thanks for your answer. your clarification makes perfect sense.
one more ques. since we keep the control valve fail open. during emergency shutdown or esd case...so this valve will go fully open.
is there a problem in that?
#6 rs20170808@gmail.com
  • 41 posts
Posted 19 April 2019 - 05:31 AM
hello chemitofraek,
1) Impeller damage
#7 breizh
  • 6,801 posts
Posted 19 April 2019 - 05:43 AM
http://www.idc-onlin...atthewPaper.pdf
To  add to the discussion , the fail position should be open to protect the pump from cavitation , overheating .
my view.
#8 Chemitofreak
Chemitofreak
  • 292 posts
Posted 19 April 2019 - 05:53 AM
hello chemitofraek,
1) Impeller damage
It will not have an impact as the pump might also trip during the ESD.
#9 fallah
  • 5,019 posts
Posted 19 April 2019 - 09:42 AM
hi fallah,
There could be no problem in all situations such as ESD case; as the pump either recirculate (if still operating) the fluid through the kick back line or will trip following to ESD command...
