Dear Latexman
I have a Temperature control valve installed in a 50% propylene+glycol and water line, used to heat Boil off gas coming from a compressor at -190 oF.
1,300 lb/hr of Boil off gas (99% Methane) is heated from -190 oF to -10 oF. The 50% propylene glycol is coming in at 90 oF and going out at 80 oF. The flow rate of GW is 16,000 lb/hr.
A temperature control valve is installed in the Glycol water line coming into the shell and tube exchanger (attached sketch). which senses the Outlet temperature of the glycol water from the exchanger and sends the required amount.
Please let me know how to set the controller output for the temperature split range for 4-12 mA, 12-20 mA.
Please let me know what other information is required to get the controller output.
