Hello everyone!
How we can check the adecuacy of an existing horizontal vessel?
Thanks in advance!
Posted 04 May 2019 - 12:11 PM
Hello everyone!
Thanks in advance!
Posted 04 May 2019 - 12:37 PM
You have to go through the requirements for the gas/liquid and liquid liquid separation criteria i.e. what is the maximum gas velocity/load factor you should allow in order not to exceed a specific liquid carry over in USG/MMSCF. You should also look into your oil/water separation requirements. Please note in case you have emulsion, such static separation in horizontal vessels will not be able to break such high oil-water tight dispersion and further separation using heating or electrostatic separation is required.
Posted 04 May 2019 - 02:44 PM
You will need to be more specific in your information and the questions you have. We know nothing of the vessel other than what you have stated, specifically it is horizontal.
As an example you mention nothing of the pressures and vacuums, application, fluids, temperatures, materials and so much more. There is no way to give you a proper answer without a proper question.
Posted 04 May 2019 - 10:13 PM
Difficult to give you a meaningful answer . Did you check for documents associated with the fabrication of the tank , data sheet , name plate , engineering drawings ,etc ?
What is the purpose of this tank ?
Help us providing more info and we will help you.
Edited by breizh, 04 May 2019 - 10:13 PM.
Posted 06 May 2019 - 04:36 PM
Panagiotis:
I have another question - besides the important points raised by ProinWv and Breizh: what do you mean by the word "adequacy"?
Do you mean:
Please be specific.
Two Phase Reverse Flow -Psv Sizing For Check Valve Failure CaseStarted by Guest_namita.modak1_* , Today, 08:15 AM |
Sizing Of Condensate Return VesselsStarted by Guest_panoska_* , 23 Oct 2025 |
Horizontal Decanter Sizing CalculationStarted by Guest_peejoee_* , 07 Oct 2025 |
Strategy For Adequacy Check Of Multiple Bdvs In A SystemStarted by Guest_nabeelsp1036_* , 22 Jan 2025 |
