Hi all,
I am working on some heat exchanger calculation. And I am getting stuck with plate and shell calculation. Could you suggest me some ways to evaluate performance or design of this type of heat exchanger?
Thank you in advance.
Posted 19 May 2019 - 10:02 AM
Hi all,
Posted 19 May 2019 - 11:43 AM
Viet:
You are a recent member, so I’ll let you do the leg work and get familiarized with the contents and vast information available to our readers and members. And by the way, the correct term is Plate and Frame Heat Exchangers - not “plate and shell”. There is no shell in this design.
Chris Haslego, the founder of ChE Resources and its Forums is the acknowledged expert in the design and implementation of Plate and Frame Heat Exchangers. Use our Search Engine and search for:
And you will find what you need. Download both and find out what you need to know about Plate and Frame design.
............and don't forget to thank Chris for his valuable contributions and efforts.
Posted 19 May 2019 - 07:51 PM
In addition to Art's comments a few documents to support your work
Hope this is helping you.
Edited by breizh, 19 May 2019 - 08:26 PM.
Posted 19 May 2019 - 08:25 PM
Dear Mr. Montemayor and Mr. Breizh,
Thank you for your responses, but the exchanger I am looking for is Plate and Shell heat exchangers, not Plate and Frame Heat Exchanger. Here is some pictures of it. And yes, it has a shell.
Hope you have a nice day.
Cuong
Edited by VietCuong, 19 May 2019 - 08:29 PM.
Posted 19 May 2019 - 08:57 PM
http://www.gesmex.com/en/dimensioning
You may consider to contact this German company for your query . it seems that HTRI has option for this particular type of HEX , circular plate and frame (shell) heat exchanger.
note: To get a meaningful answer you should tell us the issues you are facing .
Posted 19 May 2019 - 10:39 PM
Dear Mr. Breizh,
Thank you for your reply.
I checked with HTRI Xchanger Suite and there is no option for this type of heat exchanger.
As I wrote above, I am making some calculation to evaluate performance of some types of heat exchangers. And I am hitting the wall when coming up with Plate and Shell Heat Exchanger. I do not know how to determine the heat transfer coeffficient for this equipment.
Cuong
Edited by VietCuong, 19 May 2019 - 10:40 PM.
Posted 19 May 2019 - 11:34 PM
https://www.htri.net...nger-technology
Hi Cuong
take a look at the link above !
Unless you have the data sheet of the existing equipment there is no chance to get access to the heat transfer coefficient .
The heat transfer coefficient is very much linked to the design of the plate .
My view
Heat Exchanger Steam FlowStarted by Guest_aliebrahem17_* , 25 Nov 2024 |
Discussion - Predict Storage Tank Heat Transfer Precisely By Jimmy D KStarted by Guest_raj shekhar_* , 25 Mar 2025 |
Cross Over Temperature In Countercurrent Heat ExchangerStarted by Guest_panoska_* , 18 Feb 2025 |
Aspen Hysys - Blowdown Utility Heat Flux MethodStarted by Guest_yuvi.ardekar1999@gmail.com_* , 27 Feb 2025 |
