Dissolved H2S Gas Evolution From Water
hydrogen sulphide dissolved gas henrys law vle bubble point
#1 Jaydge
Jaydge
Posted 21 May 2019 - 04:52 AM
Is it possible for a dissolved gas to evolve from water if the mixture is below its bubble point temperature?
For example will H2S evolve from a water stream containing 10 ppm mol H2S if that stream is below its bubble point temperature at atmospheric pressure.
#2 thorium90
thorium90
  • 1,073 posts
Posted 21 May 2019 - 08:18 AM
Sure, if you want to remove the H2S from the water, just bubble air through it and the H2S will get stripped out.
There are also other chemical methods as well. They involve circulation inside a packed column with chemicals flowing countercurrent to H2S laden water.
#3 breizh
  • 6,939 posts
Posted 21 May 2019 - 07:36 PM
Use your favorite search engine . Keys words : Air stripping H2S
You will find description of industrial units (packed column)
http://www.trussellt...f-air-stripping
Hope this is helping you
Edited by breizh, 22 May 2019 - 01:57 AM.
