Does anyone ever tried to simulate absorption heat pump using Lithium Bromide in HYSYS? LiBr is not in HYSYS library therefore I Ihave to add it as a hypothetical component but I am not sure if adding the main properties will do the job.
Posted 22 May 2019 - 12:31 PM
Posted 29 May 2019 - 05:23 AM
Posted 02 July 2019 - 02:15 PM
If you only want a steady state ...try DWSIM. It has an example of single stage Absorption chilled LiBr based
In Hysys, For Horizontal Vessel Sizing,Started by Guest_guoyinyanliner_* , 10 Sep 2026 |
Importing Component Stream Data From Hysys To Excel Using VbaStarted by Guest_TimL_* , 17 Aug 2018 |
Sulfuric Acid Plant Aspen Hysys HelpStarted by Guest_kazuki222_* , 29 Apr 2026 |
