Distillation Separation Of 1-Hexene From 1-Butene Stream By Hysys
1-hexene hysys distillation 1-butene hexane
#1 bestday.hunter
bestday.hunter
  • 3 posts
Posted 23 May 2019 - 08:30 PM
Hello Engineers,
I Need your Help to Simulate (by Hysys) a Distillation Separation Process to separate 1-hexene from other components of 1-butene stream.
Components of 1-butene stream:
1-butene (Alpha-Olefin)
n-butane (Paraffin)
1-hexene (Alpha-Olefin) [This One is Goal]
hexane (Paraffin)
octene (Olefin)
I simulated a PFD but have problem in Separation of 1-hexene & hexane because of similar boiling points (63 and 68 Celsius). Distillation Separates them in Very High Condensor and reboiler duties (for example 800 kW).
After Search about it, I Understand it Needs Azeotropic Distillation (with another agent) or L-L Extraction Distillation (with another agent) to Distance their Boiling points to have a Simple Separation with desirable Cond. and reb. duties. But I Have Not any idea to Simulate Azeotropic Distillation or L-L Ext. Distillation for these 1-hexene & hexane.
Please Help me to Solve it...
  • 6,939 posts
Posted 23 May 2019 - 09:16 PM
http://www.freepaten...om/5385649.html
Consider the patent above to start with .
Any textbook on Distillation should help .
good luck
#3 bestday.hunter
bestday.hunter
  • 3 posts
Posted 24 May 2019 - 04:42 AM
Hi Breizh
i will report here after reading that patent.
Thanks A lot for your attention
#4 bestday.hunter
bestday.hunter
  • 3 posts
Posted 26 May 2019 - 10:43 PM
Hello Again
I read mentioned patent. it describes a condition to separate 1-hexene from hexane in an azeotropic distillation tower with DiAcetone Alcohol as Agent.
I have problem in Feed to tower. if we assume Tower Pressure is 1 atm, so Boiling Point © for:
1-hexene = 64 C
n-hexane = 68 C
DiAcetone Alcohol = 168 C   (Agent)
The Agent boiling point is much higher than Main components. so this illustrate Agent force rebolier to boil at 168 C , so Main components with lower BP will vaporize and rise up. Agent must Form Azeotrope with n-hexane to bring it toward Bottom. Therefore I conclude Bottom Product is n-hexane/DiAcetoneAlcohol and Top product is 1-hexane. Is it true?
If True, Please Help me to Simulate it with HYSYS. I Can't Separate 1-Hexane (1012 kg/hr) and n-Hexane (52 kg/hr).
Edited by bestday.hunter, 26 May 2019 - 10:46 PM.
