Double Block & Bleed Valve For Acid Gas Line
acidgas dbb sulfur recoveryunit
#1 gr8azhar
gr8azhar
Posted 03 June 2019 - 01:33 AM
Hello All,
I want your help regarding installation of double block and bleed valve in acid gas line.
We got internal recommendation to install DBB on amine acid gas & sour water acid gas lines, routed from amine treatment and sour water treatment units to sulfur recovery unit.
Kindly inform if any related standard, article or book where explained/discussed installation of double block and bleed valve on acid gas/sour gas line.
Thanks,
Azhar
#2 fallah
  • 5,026 posts
Posted 04 June 2019 - 01:45 AM
Hi Azhar,
Refer to "Isolation Philosophy" of the project you are involved in...
#3 Chemitofreak
Chemitofreak
  • 292 posts
Posted 04 June 2019 - 05:04 AM
Check project Isolation Philosophy or Client's Isolation Philosophy. If you don't have both then refer the following link
https://www.ogj.com/...facilities.html
Nice article...!
#4 breizh
  • 7,062 posts
Posted 04 June 2019 - 05:59 AM
hi,
you may find pointers in the doc. attached.
