HI there,
I want to calculate time required for venting all hydrogen gas from hydrogenator which is operated under 4Kg/cm2 through 40 mm vent.
I tried through torricelli equation but result found abnormal.
Posted 07 June 2019 - 01:46 AM
HI there,
Posted 07 June 2019 - 02:50 AM
hi ,
Please consider reading this document to support your work .
Monitoring the effectiveness of the process is key .
good luck
Edited by breizh, 07 June 2019 - 08:36 AM.
Posted 07 June 2019 - 07:58 AM
Torriceli is for liquids.
Is there a restriction orifice? Use choked flow.
Gas Blanketing Vent Size For Atmospheric Storage TankStarted by Guest_Fergie_* , 13 Apr 2026 |
Drain And Vent Destination LpgStarted by Guest_Priolo_* , 14 Feb 2026 |
Heat Of Dilution Of Hydrogen Chloride In Hydrochloric Acid Solution (3Started by Guest_fredlan54_* , 21 Nov 2025 |
Atmospheric Tank Vent SizingStarted by Guest_kmic_* , 30 Sep 2025 |
Is Emergency Venting Required For Polyethylene Storage Tank In Fire ScStarted by Guest_chem55_* , 01 Aug 2025 |
