Dew Point Plant Operating Range
dew point
#1 Ariel
Ariel
  • 49 posts
Posted 11 June 2019 - 07:45 AM
Dear all,
We have a problem. We have a 3 MMSMCD (105 MMSCFD) dew point plant (PFD attached).
The field is old and we will be approaching 1 MMSMCD (35.3 MMSCFD) gas production in two years, it is 30% of installed capacity.
Which problema could I have? Which equipment is critical and need to be revised/adjusted?
If you want/can, I would like to receive where a need to read about this topic (links, white papes, recommended papers or books, et)
Thanks in advance
Ariel
#2 PingPong
PingPong
  • 1,477 posts
Posted 12 June 2019 - 09:52 AM
You could have turndown problems in some equipment or valves.
For example:
- There are many vessels with a demisting device in it. Depending on their type these devices can have reduced removal efficiency at low throughput and may therefor need size reduction or replacement by a more modern design.
- Trays in a columns can have reduced efficiency at low capacity due to increased weeping. Trays may need to be modified by blinding off part of the holes or valves.
- Pumps may need a minimum flow bypass (back to the suction vessel).
- Compressors also have to be reviewed, including there control system, to verify that they can operate stable at reduced plant throughput.
- Some control valves may need a reduced trim to avoid that they need to operate at too small opening, which may give unstable control.
- Relief valves need to be checked to verify that they will not be too oversized causing chatter when they need to operate.
