Pi System Process Engineering Deliverables
Posted 11 June 2019 - 07:59 AM
Can anyone advise on what a process engineer is looking for after implementing PI system in his process plant?
Your advices may help in writing technical scope of work of the project and listing project deliverables
Unfortunately, I'm not familiar of such type of systems
Said Al Athobi
Posted 11 June 2019 - 02:51 PM
If your company is committing to this system my advice is to enlist a professional familiar with its application. Undoubtedly someone sold your management on the merits of the system. If you are in any way responsible for the success of this project, you should be doing a lot of research. Good luck.
Posted 11 June 2019 - 03:44 PM
By "PI System", do you mean the software system by OSIsoft?
The company I worked at did several projects for a big client that used this software, so luckily I was also able to use it.
What we were able to do (and what most process engineers who worked for that client did) was to access all (current and historic) measurements from their plants that were available in the DCS and export these measurements to MS Excel e.g., so they were available for further analysis. Without having to go to the control room, we could do all of that right from our office using a VPN connection. As most PFDs lacked a lot of information, we were able to get a lot of process data that were then used for the design of new pieces of equipment or pipelines that were retrofitted.
Hope that helps
Philipp
Posted 12 June 2019 - 09:26 AM
That's what I mean exactly Process Information System whoever is the provider(OSIsoft, Aspen IP21, Yokogawa, Honywell etc).
Mastered Process EngineeringStarted by Guest_Boudinahh8777_* , 31 Oct 2025 |
Gas Sweetining ProcessStarted by Guest_Alameerha_* , 10 Nov 2025 |
