Increasing Heat Transfer Coefficient In Shell And Tube Heat Exchanger
shell and tube he heat transfer coefficient
7 replies to this topic
#1 modianurag
modianurag
  • 17 posts
Posted 17 June 2019 - 10:34 PM
What are the methods to increase heat transfer coefficient in Shell and Tube Heat Exchanger.
Kindly share calculation/resources for the same.
#2 PhilippM
PhilippM
  • 98 posts
Posted 18 June 2019 - 03:14 PM
You should probably be more specific about your problem and include a description and/or sketch about the heat exchanger in question
Is there an existing heat exchanger that isn't performing like it is expected to?
Are you designing a new one?
#3 modianurag
modianurag
  • 17 posts
Posted 05 July 2019 - 05:04 AM
My question is more of an open ended question. I want to know what are the most common steps to improve the coefficient of a heat exchanger.
#4 latexman
  • 1,893 posts
Posted 05 July 2019 - 10:45 AM
Is it fouled?  Compare actual U to design U.  It may need cleaning.
#5 gegio1960
gegio1960
  • 518 posts
Posted 06 July 2019 - 11:57 PM   Best Answer
1) increase velocity
2) decrease fouling
#6 breizh
  • 6,937 posts
Posted 07 July 2019 - 08:54 AM
Probably good to read .
Good luck.
Edited by breizh, 10 July 2019 - 04:23 AM.
#7 tarang.suthar
tarang.suthar
  • 13 posts
Posted 01 August 2019 - 06:12 AM
Dear Mr. Breizh,
Kindly give the step for minimise the Pressure drop on Shell side??
Tarang Suthar
#8 breizh
  • 6,937 posts
Posted 01 August 2019 - 08:05 AM
Hi Tarang .Suthar ,
Please create a new thread , it will be easy to follow .
Refer to Art's comments about centrifugal pump .
Multiple resources are available, your favorite search engine together with Cheresource's engine .
Key words : heat exchanger head loss shell side .
You should also consider the documents provided in this post .
