Design Of Cold Box
cold box lng heat exchanger plate fin composite curves heat integration
#1 panoskagiou
panoskagiou
  • 103 posts
Posted 03 July 2019 - 03:22 PM
Dear all,
I would like your help and sharing your knowledge/experience on the cold box design.
Thank you in advance!
#2 Bobby Strain
Posted 03 July 2019 - 06:42 PM
You need only to develop the specifications. Then let the equipment supplier design it.
#3 Chemitofreak
Chemitofreak
  • 292 posts
Posted 04 July 2019 - 08:17 AM
Cold box is nothing but a Brazed Aluminium Heat Plate Fin Heat Exchanger.
As Bobby rightly said, you need to develop a technical specification and the vendors will design the same for you.
Refer API 668 or ALPEMA standard for the same.
#4 panoskagiou
panoskagiou
  • 103 posts
Posted 04 July 2019 - 01:08 PM
Hello to both of you and thank you for your response. Maybe, I did not epxress myself properly.
What I specifically I wanted to ask is how we start from the srcatch the design, which means how many LNG Heat exchangers we will use, how we will combine the different streams and generally its simulation.
#5 Bobby Strain
Posted 04 July 2019 - 04:31 PM
You need to do some work to show. We have no idea what your process is.
#6 cmp74
cmp74
  • 51 posts
Posted 31 August 2019 - 09:37 AM
You are basically asking to develop PFD of the new plant....This should have been team effort between your senior process people and technology provider for the new plant.Once PFD is developed,duty required for cold end exchangers along with process inlet conditions/required outlet conditions needs to be provided to specialized manufacturer/designers of cold box.They will do the remaining,however your company process department will have to be engaged with them.Kobelco,Japan is a well known manufacturer of such equipment.I hope this helps.
#7 breizh
  • 6,942 posts
Posted 01 September 2019 - 06:16 AM   Best Answer
https://www.kobelco....ex/coldbox.html
Let you contact this supplier with your spec sheet .
note : Consider your favourite search engine , key words :cold box design
