How To Calculate Flow Rate Of Water Required To Achieve Process Parame
amine plant heat exchanger duty
#1 waqaskhan746
waqaskhan746
  • 2 posts
Posted 05 July 2019 - 07:15 AM
Dear All,
I am working as a process engineer in a gas processing  plant.Our plant is designed to process 30 MMSCFD natural gas .It has two units one is Amine (MDEA) based gas sweetening and other is TEG based Gas Dy-hydration Unit.We are going to relocate this Amine Gas Sweetening plant to some other place which has kind of same day temperature while wind velocity at the new site is almost 100mph. The night temperature in summer is quite low at the night due to its only 20KM distance from the sea.There are installed shell and tube heat ex-changers to cool down the gas as well as Lean Amine.
My main question is about finding the right amount of flow rate keeping in mind the already designed cooling tower system.We have a cooling tower whose refrigeration capacity is 750 Tons.
I am sharing the re-boiler heat duty as well the heat duties of other heat ex-changers involved in the process system.There are three heat ex-changers which are installed in cooling tower ;
  1. Lean Amine Cooler with water as cooling medium.The design sheet is attached with same name.Attached File  Heat Exchangers of Amine Unit Data Sheet.pdf   277.41KB   46 downloads
  2. Amine Re-flux Condenser .The design sheet is present in Attached File  Heat Exchangers of Amine Unit Data Sheet.pdf   277.41KB   46 downloads
  3. Sweet Gas Cooler.The design sheet is present in Attached File  Heat Exchangers of Amine Unit Data Sheet.pdf   277.41KB   46 downloads
I am also attaching the P&IDs of the amine unit on which the operating/design parameters of temperature,pressure and heat duty are given.
Attached File  08002-5006-Rev 2.pdf   386.38KB   25 downloadsAttached File  08002-5011 Rev 2.pdf   479.08KB   20 downloadsAttached File  08002-5012-Rev 2.pdf   408.99KB   16 downloadsAttached File  08002-5013-Rev 2(0).pdf   372.96KB   18 downloadsAttached File  08002-5013-Rev 2.pdf   359.75KB   21 downloadsAttached File  08002-5014-Rev 2.pdf   384.71KB   17 downloads
Attached File  08002-5015-Rev 2.pdf   217.97KB   17 downloads
Now my question is that what should be the water flow rate in the supply header of cooling tower.The cooling tower is placed 150 ft away from the ex-changers.Will the cooling tower of 750 Tons capacity enough to achieve the required parameters as per data sheet of ex-changers.We have Pump capacity of circulating 1200 meter cube flow per hour.How many US gallons will be required as Make-up water.We have RO Water system of 10 m3  capacity.
Please suggest some other necessary information you think regarding relocation of  plant should be under consideration.
  • 6,956 posts
Posted 05 July 2019 - 08:01 PM
A few pointers :
*Based on energy balances on your HX , calculate the total amount of water needed for cooling ( include a safety factor ).
*Take into account your location , the temperature changes during the year and request a proposal from cooling tower vendors .
Regarding Make up water, it depends very much about the quality of your water , the chemical treatment (Blow down)and weather conditions (evaporation). Request a proposal from Chemical treatment vendors
and guarantees about performances ( number of cycles , chemical dosage)
Note : cooling towers are not that expensive , consider spare pumps .
Good luck,
Edited by breizh, 05 July 2019 - 09:06 PM.
