Net Gas Scrubber is used at Isomerization unit to neutralize HCl in Off Gases form Stabilizer with Caustic before leaving to Refinery Fuel Gas System. However, From Sometime as the Off gases flow slightly changes caustic starts to carryover in water section at the scrubber. It is understandable that the change in Off Gases Flow / Pressure is carrying over the caustic, but this thing didnot happen since the commissioning of the the unit although the changes in flows are prominent during the emergency situations.
Caustic Carryover At Refinery Fuel Gas Scrubber (Isomerization Unit)
Started by Muhammad farhan, Jul 19 2019 12:19 AM
isomerization penex net gas scrubber
Scrubber DesignStarted by Guest_syamsundar_menon_* , 02 Jul 2018 |
Handheld Ethanol Fuel Content AnalyzerStarted by Guest_Sciosophy_* , 03 Mar 2026 |
Wet Scrubber Design For Low Flow Rate Of GasStarted by Guest_SIVAMOORTHY_* , 17 Apr 2018 |
Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
