How would you condensate the overhead product of a distillation vacuum column?
If a shell&tubes heat exchanger is used to condensate this flow would it be a problem dealing with the reduced pressure?
Posted 15 August 2019 - 07:55 PM
Pressure drop is a key parameter in vacuum condensers. Use design features that tend toward low pressure drops for vacuum shell side condensing such as baffles with maximum spacing and maximum cut. Or use double segmental baffles. Use large vapor nozzles. Use a generous tube pitch. Use large shells. Consider a J shell. Exchangers for vacuum condenser service need to NOT try to use all the pressure available as when designing for other services.
Flow Through A Perforated PlateStarted by Guest_Ahmadhamzahperta_* , 13 Feb 2026 |
Gas-Liquid Pipe Flow Friction Loss CorrectionStarted by Guest_Huba_* , 18 Dec 2025 |
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
