Pneumatic Pump For The Sulfuric Acid(98.5%) Service
7 replies to this topic
#1 JKM
JKM
  • 54 posts
Posted 17 August 2019 - 02:06 AM
I need to purchase the pump for the Sulfuric Acid (98.5%). My team suggested that Pneumatic type Pump (using the Plant Air as a driving media) can be used. The primary rationale for selecting the Pneumatic Pump is purely on the cost basis.
The purpose of the pump is for draning and transfer of the Sulfuric Acid line during Maintenance.
Personally I never had experience of using the Pneumatic Pump for the Sulfuric Acid Pump.
Kindly share your opinion based on your experience whether Penumatic Pump can used for Sulfuric Acid or not.
JKM
  • 7,031 posts
Posted 17 August 2019 - 02:27 AM
You should contact vendors like Wilden ,Yamada and others . Finding the suitable material is key (diaphragm and body ) .
my view.
Edited by breizh, 17 August 2019 - 04:39 AM.
#3 thorium90
thorium90
  • 1,073 posts
As in an air operated diaphragm pump? The material selection would be important for sulfuric acid. PTFE should be suitable.
#4 JKM
JKM
  • 54 posts
Posted 18 August 2019 - 07:51 AM
Dear Breizh,
Thanks a lot for your reply and useful literature. I will contact to the suggested vendor.
Dear Thorium,
Yes it is air operated diaphragm pump. Do you have similar experience.
JKM
#5 breizh
  • 7,031 posts
Posted 18 August 2019 - 08:15 AM
https://www.wilden-pumps.co.uk/pumps
Link for Wilden .
#6 thorium90
thorium90
  • 1,073 posts
Posted 18 August 2019 - 11:45 AM
Air diaphragm pump with PTFE body and diaphragm should suffice.
#7 JKM
JKM
  • 54 posts
Posted 21 August 2019 - 10:30 AM
Dear Breizh,
Thanks a lot for the link.
Dear Thorium,
Thanks a lot for suggesting the compatible material.
JKM
#8 JKM
JKM
  • 54 posts
Posted 27 August 2019 - 10:05 AM
To update,
I got the quotation from Wilden Pump. Wilden recommends PTFE and PVDF for Sulfuric Acid. Finally selecting the PTFE Material.
Thanks a lot Breizh and Thorium for your valuable suggestion.
JKM
