Heat Exchanger- Need Of Safety Device
#1 Marri
Marri
Posted 22 August 2019 - 06:38 AM
I am designing small heat exchanger for bioplant.
In this heat exchanger outcoming  process flow from another process equipment heat ingoing process flow.
Temperature difference is only  ~10 C. All temperatures are 90-100C.
Process flow is mainly water with some biocomponents and flammables.
1) When is safety device needed in case of closed outlets/heat expansion ?
Is it always needed ? Can I estimate or calculate the need somehow?
Thank you ,
Best regards
Marri
  • 6,939 posts
Posted 22 August 2019 - 08:49 AM
4 documents to support your work  . Seniors Engineer within your organization should support you .
Edited by breizh, 22 August 2019 - 11:30 PM.
