Could someone explains how the pressure drop across the strainer/control valve/flow elements are calculated?
Posted 10 September 2019 - 06:08 AM
Posted 10 September 2019 - 06:20 AM
If you are a chemical engineer you should refer to your textbooks .
To support your work you should consider to get a copy of the famous Flow of Fluids through valves, fittings and pipe from Crane , also known as Technical paper N0 410 M .
A few links from internet .
http://fekete.com/SA...alculations.htm
https://neutrium.net...ings-2k-method/
http://www.pressure-drop.mobi/
https://www.control-...com/worksheets/
https://checalc.com/index.html
http://www.fao.org/3...44e09.htm#3.7.1
http://seperationtec...-and-strainers/
Note : You could also use the search engine in this forum , in particular check for Aioflow a software developed by Katmar, a member of this forum .
Edited by breizh, 11 September 2019 - 03:44 AM.
Posted 12 September 2019 - 12:27 AM
Generally these are finalised based on the pressure drop available in the system.
If it is pump circuit, it is good engineering practice to use pressure drop of control valve and flow instrument (orifice) as 0.7 bar and 0.25 bar respectively.
Shell And Tube Pressure DropStarted by Guest_UofUChemE_* , 08 Jun 2018 |
Pressure BuildupStarted by Guest_Yankee_* , 31 Mar 2026 |
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
