The flow orifice of process air compressor discharge in our plant is compensated for discharge pressure and but the uncompensated flow is used in controller of the blow off valve of the compressor.
But the process air is heated through a fired heater and the flow at the outlet is pressure and temperature compensated and the compensated flow is used for logic in air flow low trip.
So on what logic do we decide whether the compensated or uncompensated flow is to be used for trip logic
Flow Compensation In Trip Logic
Started by muthukmaar, Sep 17 2019 11:45 AM
Posted 17 September 2019 - 11:45 AM
Posted 17 September 2019 - 05:34 PM
You should really include a small sketch in order to explain more clearly what this process looks like and what the trip logic is supposed to do
See also point 4. of https://www.cheresou...ting-questions/
Flow Through A Perforated PlateStarted by Guest_Ahmadhamzahperta_* , 13 Feb 2026 |
Gas-Liquid Pipe Flow Friction Loss CorrectionStarted by Guest_Huba_* , 18 Dec 2025 |
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
Flow & Pressure Regulation For Compressible FluidsStarted by Guest_Abdessamed1961_* , 14 Dec 2025 |
Calculating Gas Flow Rate Without CvStarted by Guest_worrier_* , 25 Nov 2025 |
