Effects Of Temperature On Compressor
Started by Krushit, Oct 10 2019 01:28 AM
Posted 10 October 2019 - 01:28 AM
In refrigeration cycle, Freon Screw Compressor has suction temperature and pressure as 1 DegC and 3 barg and Discharge Temperature and pressure as 70 DegC and 14 Barg.
What would be the effect on compression if the suction Temperature is increased by 5-10 DegC with help of high Temperature compressor discharge stream in a heat exchanger?
Posted 10 October 2019 - 06:37 PM
Why would you entertain such a scheme?
Posted 12 October 2019 - 02:06 AM
I was just having a thought, if i could reduce the discharge temperature of compressor than i could do furthur subcooling of freon which will reduce my freon quantity required in the evaporator. And thus i could save on my compression cost.
Is it possible to do so?
Posted 12 October 2019 - 04:19 AM
Maybe you should provide two sketches or PFDs with the process data (as it is right now and with what you want to change) and a calculation to explain your idea
Posted 12 October 2019 - 08:55 AM
Okay. I will try
Relieving TemperatureStarted by Guest_Falah_* , 01 Feb 2026 |
Compressor Selection Based On Flowrate & Compression RatioStarted by Guest_Dhams_* , 19 Jan 2026 |
Purge Gas For Centrifugal CompressorStarted by Guest_Lyne_* , 19 Oct 2025 |
