Simulation Of Heat Exchangers With High Flux Tubes In Htri7
htri edr heat exchanger simulation rating high flux high flux tubes heat transfer reboiler exchanger
#1 abolghasem202
abolghasem202
  • 17 posts
Posted 15 October 2019 - 06:43 AM
Dear all,
I need to simulate a special heat exchanger. It is the reboiler of a C3 splitter column. Our vendor proposed a heat exchanger with high flux tubes. I have been studying about these tubes and I think that the overall heat transfer coefficient of this exchanger should be higher than a exchanger with plain tubes.
Is it possible to simulate a heat exchanger with high flux tubes using HTRI or Aspen EDR?
I would appreciate your suggestions.
Attached File  Tube types.png   2.78KB   4 downloads
  • 1,657 posts
Posted 15 October 2019 - 08:23 AM
You can choose 'UOP High Flux' tubing in HTRI. You do not see this option available until you install the UOP High Flux tube DLL. Contact UOP.
