Anyone can simply calculate differential head using the density if we have provided the differential pressure. Then why do we specify differential head separately? It seems redundant.
Why Do We Specify Differential Pressure As Well As Differential Head I
Started by abcd63b, Oct 16 2019 09:26 AM
pump pds pump datasheet pump datasheet
No replies to this topic
Posted 16 October 2019 - 09:26 AM
