Anyone can simply calculate differential head using the density if we have provided the differential pressure. Then why do we specify differential head separately? It seems redundant.
Why Do We Specify Differential Pressure As Well As Differential Head I
Started by abcd63b, Oct 16 2019 09:27 AM
pump pds pump datasheet pump datasheet
Posted 16 October 2019 - 09:27 AM
Posted 16 October 2019 - 01:02 PM
It is redundant. The specification should be head for a centrifugal pump since this is the fundamental function of a centrifugal pump. Not so for a positive displacement pump, for which pressure differential is appropriate.
Pressure BuildupStarted by Guest_Yankee_* , 31 Mar 2026 |
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
