Anyone can simply calculate differential head using the density if we have provided the differential pressure. Then why do we specify differential head separately? It seems redundant.
Why Do We Specify Differential Pressure As Well As Differential Head I
Started by abcd63b, Oct 16 2019 09:27 AM
pump pds pump datasheet pump datasheet
Posted 16 October 2019 - 09:27 AM
Posted 16 October 2019 - 01:02 PM
It is redundant. The specification should be head for a centrifugal pump since this is the fundamental function of a centrifugal pump. Not so for a positive displacement pump, for which pressure differential is appropriate.
The Basis Of Calculation To 3% Pressure Loss At The Inlet Of PressureStarted by Guest_phoenixmoca_* , Yesterday, 01:25 AM |
Mdmt Basis For Gas Let-Down From High-Pressure Storage (Non-Blowdown CStarted by Guest_naghizad_* , 27 Feb 2026 |
Flow & Pressure Regulation For Compressible FluidsStarted by Guest_Abdessamed1961_* , 14 Dec 2025 |
