Dear:
I would be so pleased if someone clear for me that in new generation of RO desalination , for what reason the seawater before entering the desalination must be acidified?
Best regards
M.R.RAHIMZADEH
Posted 18 October 2019 - 12:37 AM
Dear:
Best regards
M.R.RAHIMZADEH
Posted 18 October 2019 - 05:30 AM
If you can share the process flow, that would be helpful. There are many reasons why people adjust pH before entering a process unit. It normally has to do with the purpose of the process unit. I'm guessing its because of the pre treatment process and it requires a lower pH to work.
Posted 18 October 2019 - 08:03 AM
https://www.oas.org/...oea59e/ch20.htm
Hope this link is going to support your work .
Posted 19 October 2019 - 06:26 AM
The other possibility is scaling control. But the pH to control depends on what is the configuration of the RO system as in the number of passes and stages, as well as the post treatment process that is used, which depends on the final intention of the treated water. One must note that RO systems inherently reduce pH, so dropping the pH in the feed too low affects the downstream process.
Acetic Acid Plant Using The Cativa Process.Started by Guest_Pilargalizia_* , 02 Jul 2026 |
Convertor Performance For Sulphuric Acid GenerationStarted by Guest_Ranga v_* , 01 Jun 2026 |
Sulfuric Acid Plant Aspen Hysys HelpStarted by Guest_kazuki222_* , 29 Apr 2026 |
Heat Of Dilution Of Hydrogen Chloride In Hydrochloric Acid Solution (3Started by Guest_fredlan54_* , 21 Nov 2025 |
