Photolytic Sulphur Ammonia Thermocycle Process
No replies to this topic
#1 Mansi
Mansi
  • 3 posts
Posted 05 November 2019 - 09:34 AM
I have defined all the list of components necessary for this process and the chosen property method was (ENRTL-SR). I chose Gibbs reactor to simulate the low-temperature reactor, high-temperature reactor, and chemical absorber because the kinetics of the reactions is not known. Also, the Rstoic was chosen to simulate the photocatalytic reactor.
The images below contain the photolytic sulphur ammonia process schematic and chemistry and a proposed ASPEN PLUS flowsheet for the process (https://www.energy.g...r_thermo_h2.pdf). I am given only one operating condition for the reactor, namely the temperature, and the production rate of hydrogen. First of all, how can one approach this design problem, given only these info. I can emulate the proposed flowsheet but I have alot of doubts,like , what valid design specifications can I define in order for material and energy balances streams to converge. I added the same blocks as in the ASPEN process flowsheet but I am stuck on how to continue from here.
  • Attached File  1.png   368.97KB   0 downloads
  • Attached File  2.png   131.36KB   0 downloads
