Vessel Depressurisation Flow Rate
8 replies to this topic
#1 Ranga v
Ranga v
  • 28 posts
Posted 09 November 2019 - 09:24 AM
We have a dryer to remove moisture from the compressed air, During regeneration of media vessel will have to be depressurized need to design a vent size to depressurize in 15 mints .
Vessel cap :15 m3, depressurization pr -: 7 to 0.2 kg/cm2g. temp 35 Deg C
I would to build this in excel sheet please provide the guidance
  • 6,964 posts
Posted 10 November 2019 - 02:17 AM
https://www.vmacair....k-simple-logic/
The link above may support your query.
#3 astro
astro
  • 121 posts
Posted 11 March 2020 - 03:08 AM
The Grote equation could help:
https://webwormcpt.b...ual-method.html
#4 Sharma Varun
Sharma Varun
  • 125 posts
Posted 11 March 2020 - 05:25 AM
As per my understanding you don't need to depressurize till 0.2 kg/cm2g within 15 min, limit depressurization upto 3.5 kg/cm2g in 15 min.
#5 breizh
  • 6,964 posts
Posted 11 March 2020 - 08:20 AM
You may be interested with this excel sheet I prepared a few months ago, based on Mike Beychock's text .
This is an old post , Nov '19
Edited by breizh, 11 March 2020 - 08:24 AM.
#6 ADR
ADR
  • 19 posts
Posted 19 November 2020 - 11:58 AM
Hello Breizh
Is there any procedure / calculation you are aware of for depressurizing a vessel containing liquid (water). We have pressure vessel operating at 110 barg, for maintenance we would like to isolate the vessel and reduce the pressure to atmospheric. Any input would help!
#7 breizh
  • 6,964 posts
Posted 19 November 2020 - 05:18 PM
Hi  ADR,
Sorry I cannot help , let see what others have to say.
#8 Pilesar
  • 1,648 posts
Posted 19 November 2020 - 05:42 PM
Open the drain to release the water from the vessel. What's the problem?
#9 breizh
  • 6,964 posts
Posted 19 November 2020 - 10:42 PM
Can you share with us a PID or PFD ?
How big is the tank? Do you have way to drain it and release the pressure ?
Do you have past experience performing the task ?
thanks in advance.
Edited by breizh, 20 November 2020 - 05:37 AM.
