why do not calculate under 10K by aspen plus?
Posted 18 November 2019 - 08:53 PM
Posted 19 November 2019 - 12:04 AM
Posted 19 November 2019 - 08:21 AM
If you want the right answer, you have to ask the right question.
Posted 20 November 2019 - 08:05 PM
If you are asking why Aspen Plus doesn't allow for calculations at temperatures below 10K, then I think you have to look into the different property method routine limitations. My guess is that none of the methods in Aspen Plus are reliable at that low of a temperature.
Aspen Hysys Simulation Of Acid Gas Removal UnitStarted by Guest_R.t_* , 22 May 2025 |
Modeling Liquid Metals In Aspen PlusStarted by Guest_AnthonyB_* , 03 Apr 2025 |
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
Aspen Hysys - Blowdown Utility Heat Flux MethodStarted by Guest_yuvi.ardekar1999@gmail.com_* , 27 Feb 2025 |
No Liquid Phase In Aspen PlusStarted by Guest_PengRobinson_* , 09 Feb 2025 |
