Formaldehyd Scrubber/column
venturi spray scrubber packed column
#1 Xambis
Xambis
  • 3 posts
Posted 05 December 2019 - 10:09 AM
Dear Cheresources Community,
This is my first post and I am having some issues with a  ongoing regarding gas scrubbing/columns for particulate matter and gas absorption.
The goal is to clean a fairly large  gas flow rate from a diluted particulate matter and formaldehyde concentration. The inlet values are for 400000 m³/h , 200 mg/m³ and 45 mg/m³ respectively. The outlet goal is < 30 mg/m³ and 10 mg/m³ respectively.
Now, the particulate matter scrubbing is planned to be done by a venturi or spray tower (depends on PSD) and until now a few vendors have suggested one or 2-4 absorption columns for Formaldehyd-Absorption using water as solvent.
I have read quite a few Information about Formaldehyd and its simultaneous reaction with water. However, according to henrys-law.org there are a few Henry-constants that have indeed accounted for hydration reaction and have fairly small values. I have regressed the BI -parameters for NRTL and UNIQUAC based on experimental data and also conclude to a fairly good absorption in water.
I was wondering if anyone has any experience on mass transfer rates in the Venturi or Spray tower and if you think a fairly expensive packed column can be avoided. Unfortunately the vendors refuse to really take a closer look as the project itself is in an early stage.
I appreciate your answers
Best
Xambis, Chemical Engineer
#2 thorium90
thorium90
  • 1,073 posts
Posted 05 December 2019 - 10:16 AM
Based on the numbers you have mentioned, I would agree that venturi scrubber is a very reasonable option to use.
#3 Xambis
Xambis
  • 3 posts
Posted 05 December 2019 - 11:07 PM
I would also go with a venturi or a spray tower, however I need to quantify that in terms of mass transfer.
Best
Xambis
#4 breizh
  • 6,942 posts
Posted 05 December 2019 - 11:27 PM
I'm not sure what you expect from us . I've attached some literature to support  your work .
https://www3.epa.gov...ts/fventuri.pdf
Note : You will find other documents issued by Ankur using the search engine in this Forum .
Edited by breizh, 06 December 2019 - 03:23 AM.
#5 Xambis
Xambis
  • 3 posts
Posted 06 December 2019 - 07:35 AM
Hello Breizh,
Thank you very much for the attached files. Especially the article regarding the spray scrubber!.
I was just asking if anyone has had any experience with a similar issue.
Best
Xambis
