This question is for amine expert in the group.
I was wondering what frequency you recommend for removing charcoal from amine charcoal filter.
Posted 30 December 2019 - 12:36 PM
Posted 06 January 2020 - 12:52 AM
Originally it was every 6 months, the plant where I worked. However we changed and we see the quality of amine also. Foaming tendency in amine absorber and RSH in lean amine can tell you when it is required to change the charcoal.
Posted 06 January 2020 - 01:14 AM
https://www.cheresou...rcoal-backwash/
Probably good to read !
You should consult your licensor or revert to the operation manual where this should be described .
Consider also the document attached ( page 42 …)
My 2 cents
Edited by breizh, 06 January 2020 - 02:13 AM.
Choosing The Right Type Of Evaporator For Removing Hcl From Aqueous SoStarted by Guest_anggara_* , 09 Feb 2026 |
Fire Case Psv For Lean Glycol FilterStarted by Guest_Arsalan_1992_* , 08 Nov 2025 |
Sizing And And Process Control Of Filter PressStarted by Guest_Amalina Jamil_* , 11 Mar 2019 |
Amine(Mdea) StorageStarted by Guest_abdullah1320_* , 17 Jun 2024 |
Carbon Bed Filter CalculationsStarted by Guest_kyayura_* , 25 Jul 2023 |
