Why Is Heat Produced When We Add Water (H2O) To Calcium Oxide (Cao)?
Posted 30 December 2019 - 12:40 PM
Posted 30 December 2019 - 07:12 PM
From literature :
CaO (s) + H2O (l) --- > Ca (OH) 2 (aq) (∆Hr = −63.7 kJ/mol of CaO)
exothermic reaction
Check for slaking of lime using your favorite search engine .
Edited by breizh, 01 January 2020 - 06:20 AM.
Posted 31 December 2019 - 11:24 AM Best Answer
The elements Ca, O, H changed to a lower energy state giving that energy to the environment. It became a more stable (lower energy) form.
Posted 02 January 2020 - 02:00 AM
This is the best and simplest explanation possible. Even a layman can understand that...!
Heat Of Dilution Of Hydrogen Chloride In Hydrochloric Acid Solution (3Started by Guest_fredlan54_* , 21 Nov 2025 |
Water Hammer In CondenserStarted by Guest_Ahmadhamzahperta_* , 31 Oct 2025 |
Shell And Tube Heat Exchanger In HtriStarted by Guest_Sanjayr126_* , 28 Sep 2021 |
