Level Switch
#1 AndyChemEng
AndyChemEng
  • 45 posts
Posted 17 January 2020 - 04:45 AM
Hi all,
I have an issue with a high level switch in a vessel that activates periodically when we charge powder into the vessel.
It is a vibrating tuning fork design.
Is there any other model types that could be used that might be more suitable at not falsely activating when powder charging?
The vessel already has a radar probe installed and this high level is additional protection against overfill.
Andrew
  • 6,349 posts
Posted 17 January 2020 - 07:33 AM
My experience with fork on powder is similar to yours . How big is your silo?
By chance can you install load cells or a second radar ? more expensive but works.
Note : Take a look at the link underneath , you may contact them for your application :
https://www.th.endre...vel-measurement
Edited by breizh, 18 January 2020 - 04:36 AM.
#3 thorium90
thorium90
  • 1,073 posts
Posted 17 January 2020 - 09:03 AM
Or maybe you could give the tuning fork a shade?
#4 AndyChemEng
AndyChemEng
  • 45 posts
Posted 04 June 2020 - 09:48 AM
Thank Breizh / Thorium,
We operate with pressure pads to monitor/control the volume from a process perspective. The level switch is for protection against overfill.
I think we are going to attempt to install a spray-ball adjacent to the switch with the hope that this prevents a build-up of powder accumulating.
The shade idea may be a possible alternative if this proves unsucessful.
Thanks for the replies.
Andrew
#5 thorium90
thorium90
  • 1,073 posts
Posted 04 June 2020 - 10:11 AM
Or maybe, put some compressed air nozzles aimed at at the fork area to blow the dust off of it every now and then.
#6 breizh
  • 6,349 posts
Posted 04 June 2020 - 06:22 PM
You might consider other technology more reliable these days , check with VEGA for their new generation of radar .
https://www.vega.com...ion/vegawave-61
Edited by breizh, 05 June 2020 - 06:05 AM.
