Effluent Heat Exchanger
tube side velocity
#1 274@P6
274@P6
  • 43 posts
Posted 22 January 2020 - 12:46 AM
Hi to all,
1. Which type of heat-exchanger will be used for cooling effluent with 25000mg/l of liquid specific gravity around 1. TSS - 100mg/l and pH 7-8.
Effluent should be cooled from 60 to 35 dec C. flow rate 133m3/hr with 2.5bar_g pressure.
2. If i use shell and tube heat exchanger (effluent in tube side due to corrosive in nature) in EDR, tube velocity is around 0.06-1.1m/s. is this velocity is enough to overcome the particle deposit/choke in the tube?
  • 6,939 posts
Posted 22 January 2020 - 01:04 AM
I would suggest a spiral heat exchanger if you are worried about deposit (easy to clean) , a brochure is  attached .
Hope this is helping you.
Edited by breizh, 23 January 2020 - 12:33 AM.
#3 274@P6
274@P6
  • 43 posts
Posted 23 January 2020 - 12:38 AM
is there any sizing calculation sheet/software to find the size of spiral heat-exchanger and cost also?
I am using Aspen EDR. No more spiral type in EDR.
#4 breizh
  • 6,939 posts
Posted 23 January 2020 - 01:26 AM
I believe these type of HX is included in software packages like HTRI . I don't know about your package .Anyway you will find a method to size this equipment in the attachment .
Regarding cost , only vendor can support .
To make it simple your should issue a spec sheet and ask vendor like Alfa Laval to size and quote the equipment .
Note :Engineering is hard work , not copy and paste. You need to build your expertise , consult peers and senior engineers /managers within your organization .
My view
