There is a waste to energy power plant operating on Rankine Cycle and it is to produce 20 MW. Based on this information only, i need to find the mass of steam to be fed to the turbine. I need to assume the isentropic efficiency, efficiency of turbine and generator, inlet pressure and temperature and outlet pressure and temperature. Anyone can help finding a reliable source ?
Efficiency Of Steam Power Turbine
Started by Noay, Feb 17 2020 02:20 PM
#steamturbine #isentropicefficiency efficiencyofgenerator rankinecycle
Posted 17 February 2020 - 02:20 PM
Posted 17 February 2020 - 10:52 PM
https://www4.eere.en...ol/equipTurbine
Consider this resource, examples are available .
Steam Carrying Liquid From The Sour Water Stripping TowerStarted by Guest_kaidlut_* , 12 Sep 2024 |
