How can you know the total amount of working fluid needed in an Organic Rankine Cycle?I am simulating the process via ASPEN HYSYS, is there any information in the software that can help me get an accurate number? I need to know the amount so that I can use it in calculating the cost of the woring fluid
Working Fluid Charge In Orc
Started by Noran Shedid, Mar 20 2020 04:22 PM
working fluid orc organic rankine cycle
No replies to this topic
Posted 20 March 2020 - 04:22 PM
Supercritical Fluid Flowrate - He Tube RuptureStarted by Guest_flarewolf_* , 07 Apr 2025 |
Two-Phase Fluid Flow Through An OrificeStarted by Guest_frwvelandria_* , 13 Oct 2025 |
Pipe Fluid Temperature Increase Due To Solar LoadingStarted by Guest_HeemeshJ126_* , 06 Apr 2016 |
Recommended Fluid VelocityStarted by Guest_crn_* , 16 Apr 2025 |
Time Required To Heat Up A Fluid In A VesselStarted by Guest_panoska_* , 24 Jan 2023 |
