Aspen Hysys Calculation Of Standard Liquid Voumetric Flow Rate For Ngl
#1 Vegeta
Vegeta
  • 133 posts
Posted 12 April 2020 - 04:06 AM
Team,
I am simulating a propane stream in the NGL plant and I have the following question:
How does Aspen HYSYS calculate the standard liquid volumetric rate of the low boiling point liquids i.e. at what temperature and pressure?
I have been using Aspen HYSYS for more than 3 years and I'm used to reference the standard liquid volume to 60 °F and atmospheric pressure.  However, this has been my first time to deal with low boiling point liquids. The liquid propane boils at -44 °F at an atmospheric pressure.  So, it shall be vapor at 60 °F.  The HYSYS results are not inline with this as follows (as an example):
Mass flow rate = 102175 lb/h
Density at -44 °F (and 30 psig) = 36.4 lb/ft3
Actual volumetric rate at -44 °F (and 30 psig) = 2807 ft3/h
the standard volumetric rate of the same stream by HYSYS = 3211 ft3/h
This corresponds to a density = ~31.8 lb/ft
However, there is no way the stream is liquid at 60 °F and atmospheric pressure.  Am I missing something here?
Your help is appreciated...
#2 Bobby Strain
Posted 12 April 2020 - 09:25 AM
You need to find the definition for standard liquid volume. It's not the same condition as gas volume at STP.
#3 breizh
  • 6,963 posts
Posted 12 April 2020 - 09:30 PM
http://users.rowan.e...ty packages.pdf
Consider this resource to support your work .
#4 Vegeta
Vegeta
  • 133 posts
Posted 13 April 2020 - 02:29 AM
Thanks Bobby and Breizh...
The answer is in the pages 55 to 59.
