Hi everyone,
Could you please explain why a particle size distribution obtained from screening is different as compared to if you measure particle size according to their sedimentation rate in a fluid?
Thanks a lot
			Posted 25 May 2020 - 12:41 AM
Hi everyone,
Thanks a lot
			Posted 25 May 2020 - 09:21 PM
Particles tend to stick together on the way down while settling. Along the way down, smaller particles get grabbed on in larger particles wake and affects their sedimentation rate.
Particles can also get chopped up or pushed together due to the screening process itself.
Unless you have very discrete particles like sand and in non sticking fluids that the particle separates easily out from.
| Maximum Velocity For Piping In Fire Water Distribution System (Fire WaStarted by Guest_applepe_* , 06 Sep 2024 |
|   Manual Depressurisation - How To Determine Restriction Orifice SizeStarted by Guest_FUNMILAYO_* , 14 Oct 2020 |
|   Free Screen Vent SizeStarted by Guest_R2012_* , 28 Jun 2024 |
| How To Right Size A Vapor Recovery Unit (Vru)?Started by Guest_MethanolPlant_* , 29 Apr 2024 |
|   Liquid Nitrogen DistributionStarted by Guest_Estiqaatsi_* , 23 Jan 2024 |
