My name is Mohammed , I am still new to this field which is Lubricants …..
Here is my situation & what I need from you guys to recommend it to me …
All of us we know what we mean by ( Lubricant Blending Process ) which is :-
Lubricant blending process , comprises mixing different materials boiling in the lubricant boiling range to make a final homogenous product. Usually a higher viscosity lubricant will be blended with a lower viscosity lubricant to achieve a blended lubricant of intermediate viscosity.)
Here in my country – Egypt - , I have studied the Market , and I found the most required products are following :-
- ( 20 W 50 – SL ) – ( 5 W 30 – SN ) – ( 15 W 40 C I 4 ) – ( 15 W 40 CH 4 ) – ( 20 W 50 CH 4) –( Hydraulic 68 ) – ( CF 50 ) – ( CD 50 ).
For more information , I have the Formula for ( 20 W 50 – SL ) & let me share it with you as an example .
Because I need to know how to prepare it in the Production environment (blending Vessel) .
- Base Oil ( virgin base oil ) – SN 150 = 8.5 %.
- Base Oil ( virgin base oil ) – SN 500 = 75.9 %
- SL/CF PACKAGE ( from Additive company called – Lubrizol ) = 6.5 %
- Viscosity Index Improver ( VII ) ( from Additive company called – Lubrizol ) = 9.0 %
- Pour Point depressants ( PPD ) ( from Additive company called – Lubrizol ) = 0.1 %.
Here is my question , I want to know if there is any Training I can Attend by myself to know how to prepare the product ( 20 W 50 SL ) on small scale first using digital magnetic stirrer hot plate in my Lab as first step.
As second step once I make sure the sample which I prepared is correct and it meet the requirements of ( 20 W 50 SL ) , I will Immediately implement on Big scale which is in blending vessel which is almost ( 5 Metric Tons = 5,000 LTR ) .
My question in very simple way , which one is put first , then heat to which degree , then add what else , then do what else as next ? shall I put ( SN 150 ) first , or ( SN 500 First ) and then do the blending while the heater is working & to which degree ? should be 80 degrees Celsius , or what ?
Can anyone recommend also good institute can teach me how to prepare / Implement the Products ?
I have all the required formulas , from Lubrizol & Unfortunately , I am the only one who is supervising this project .
Please advice me ASAP .
